marksport »
https://forums.nicoclub.com/marksport-u11501.html
Wed Jul 11, 2007 7:19 am
Ahmed, that unit can work on your car, but it is not the factory ballast for the Q45. It is for the I35, Qx4, ect. The Q45 ballast uses an internal ignitor pack, whereas that unit you see the black block the size of a relay, it is the external ignitor. You probably won't need to do any major modification. This is what I would do:
1. Disconnect the battery. Remove the bumper cover and headlight assembly. Get a copy of the FSM. Plan to spend a 1/2 a day doing the entire work.
2. Disconnect the factory plug going into the ballast pack at the bottom of the headlight. Check to see if it is compatible with that pack. If it is, simply plug it in. If not, you will have to cut the connector off the headlight harness and the ballast pack, and install new connectors. I would go with these weatherpack:
They are easily available, and if you need to go back to the factory connector, get another weatherpack and connect it together. Weatherpack connectors install easy as you just need to strip the wire, slide the weatherproof boot on and insert the terminals. Make sure you have the correct polarity before you insert the terminals.
3. Remove the connector off the old ballast pack and keep it off to the side if possible. You can remove the old pack by first removing the aluminum connector cover, unscrewing the 3 bolts that hold the pack to the headlight and carefully pulling the connector wires out. This is quite tricky and installing a new pack is just as difficult. If the ballast pack is really dead, you can also just cut the wires and pull each piece from their location. Otherwise that connector can stay inside the headlight. Consider getting a rubber bulb cover from a Yamaha R1 or Honda, or most other bikes. This will keep dust and moisture out of the headlight. Connect the new plug onto the bulb. Install the headlight, and find a new mounting point for the ballast pack as it may likely not be possible at the factory location. Test to make sure it powers up correctly. Put the rest of the front back together.
