2002 XTerra steering issue
flywatt
Car: 2002 XTerra 4x4
This is the weirdest steering problem I have personally dealt with. I pray someone out there has a solution. I bought this truck a few years ago, and I absolutly love it. I moved it from Texas to Washington, and every since my arrival I've had steering problems.
The power steering seems to work fine when I'm taking a right turn. However, when I turn the wheel left, the power steering is gone! It'll still turn, just extreemly difficult. Most noticable at a complete stop or slow speeds.
I'd greatly appreciate any suggestions or solutions.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Start with the obvious stuff. Have you checked the PS fluid and belt?
Look for leaks on the steering box as well. This sounds like either air in system, or a dying pump to me. The power assist when the truck is at low idle isn't much. Our Xterra and many others do this as well.
flywatt
Checked the fluid and belt, looks good. I'm not too sure how to check for air, I'll probably have to have a mechanic do it. Thanks for the suggestions. Greatly appreciated.
NM50
Car: 94 D21,98 03 hummer H2,66 311 CA18ET ROADSTER,94GEO METRO pimp mobile
I have found the steering box on the late (w)D22's to do that.The suspect is the recirculation balls sticking. Although we have just replaced the boxes I suspect you could O/H the box.
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
Flywatt, Give me an E-mail that can accept a 2MB file and can send you the electronic PDF file for the steering systems in a 2000-2004 Xterra.
Cheers!
flywatt
Done, thanks a bunch. Took the XTerra to a mechanic, and he had no idea what is causing it. Still no closure. Hope this helps. Thanks again.
MartyC61
Car: 1995 Nissan Altima GLE 2002 Nissan X-terra SE Supercharged
supercharger issue and steering issue after 136,000 miles. Is my '02 xterra reaching it's lifespan?
