2002 vs 2001 valve covers ignition coil.
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
Hey all,
There has been a lot of discussion on the g35/z forums about finding a way around the full plastic valve cover replacement when spark plug seals go bad. My question is a little easier, I'm wondering if the 2001 Aluminum valve covers will fit no problem on the 2002, my question arises based on the coil pack designs from 01-02. The 2001 has a different coil pack on one cylinder, where as the 2002-2004 use the same pack on all six.
If I swap to 2001 aluminum covers, will I have an issue with the 2002 coil pack not fitting properly where the 2001 has the funky coil pack?
If anyone doesn't know, the 2002-2004 with plastic valve covers do not have replaceable spark plug tube seals (to my knowledge) and therefore to fix a leaking tube seal the entire valve cover needs to be replaced (aprox $500 for the pair) the 2001 vq35de in the r50 has everything replaceable on aluminum valve covers.
Thanks guys!!
