2002 ser spec-v motor swap
gspotauto
Car: 2002 sentra se-r spec-v
i need help to figure out if it is posible to take the blue bird sr20det and put it in to the 2002 ser spec-v. i hope some one could help with this problum im having. i have found a guy that has a blue bird motor but i allso need to know what year motor i need to do it if it is posible
nametakennow
Car: '06 MINI Cooper S
You'll have to finagle the mounts. I've seen SR swaps into Specs. I believe it is as simple as a F/R mount crossmember and an SR transmission swap.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
As long as you use the motor mounts from a SR powered B15 along with the crossmember, you won't have any issues at all. Just use the axles from the SR powered B15 as well. So that would mean 2000-2001 SE or SE P/P, depending on if you get a SR transmission that is non LSD or LSD.
gspotauto
i heard that i can use the stock 6spd trany if i get the right adaptor plate is that true?
nametakennow
The adapter kit is a bit pricey and I'm not sure how many have actually been made. Run a search for a member by the name of Trav4011, he makes them.
OneFastStanza
Car: '02 Nissan Sentra SE-R Spec V
'92 Nissan Stanza
'97 Nissan Maxim
'04 Saturn Vue Redline
'04 Ford F250
nametakennow wrote:The adapter kit is a bit pricey and I'm not sure how many have actually been made. Run a search for a member by the name of Trav4011, he makes them.
Yeah Travis is your best bet for info into this. That and he has done several different types of swaps into B15s.
gspotauto
how do i get intuch with travis about the adaptor plate for the trany?
nametakennow
gspotauto
does anyone know where travis is from?
OneFastStanza
'92 Nissan Stanza
'97 Nissan Maxim
'04 Ford F250
gspotauto wrote:does anyone know where travis is from?
He lives in Louisiana close to New Orleans last I heard. I am assuming he is still located there.
gspotauto
anyone know where i can get the wiring diagrams for a 2002 se-r spec-v to sr20det motor swap
gspotauto
does anyone know about the the gas peddel isue on the motor swap from the 2.5l to the sr20det and what i can do to fix it. one is fly by wire and one is cable driven. please help
OneFastStanza
'92 Nissan Stanza
'97 Nissan Maxim
'04 Ford F250
gspotauto wrote:anyone know where i can get the wiring diagrams for a 2002 se-r spec-v to sr20det motor swap
Well as far as the wiring diagrams go I am sure there is one out there to tell you how to change them however worst case scenario you can get a FSM for both cars and rework the wiring from there. I know there are some floating around online so you can do a search and it should turn up.
nametakennow
gspotauto wrote:does anyone know about the the gas peddel isue on the motor swap from the 2.5l to the sr20det and what i can do to fix it. one is fly by wire and one is cable driven. please help
I'd get in touch with Travis on that as well. He's got the most experience with that swap.
gspotauto
anyone know who elce might make the adaptor plate i need for my trany to bolt up to the sr20det. I need to get my car on the road and travis is not responding. please help
OneFastStanza
'92 Nissan Stanza
'97 Nissan Maxim
'04 Ford F250
gspotauto wrote:anyone know who elce might make the adaptor plate i need for my trany to bolt up to the sr20det. I need to get my car on the road and travis is not responding. please help
Unfortunately I don't know if anyone else has messed with it other than Travis.
nametakennow
Everyone who has messed with it had him do it. Sorry for the bad luck there.
LuKA
Trav also does the VQ35 swap, that's what you should be after anyway.
nametakennow
Yes, because 300whp (with boltons) in a FWD econobox is so drivable.
I think VQ swaps are a waste of time. Sure, it's quick, but as soon as you go to turn or stomp on it in any situation but an absolutely straight line, you fight torquesteer and end up miserable.
I know plenty of people will argue against that. It's just another perspective on swaps.
Trav's best piece of work is the SQR23DET, if I've got that designation right. Something like 9000rpm, a giant powerband, and as much power as a VQ, if not more. Still pointless in real-world conditions, but for the power-hungry, a more interesting and better setup.
