Just bought my son a 2002 Sentra and it's obvious that the dipstick has been swapped out with a generic dipstick and I suspect that it is not adjusted properly.
Q1? What should the dipstick length be from the BOTTOM TIP to the top of the entry port?
Q2? What should the length be from the BOTTOM TIP to the LOW marker?
Q3? What should the length be from the LOW marker to the FULL marker?
Q4? .. and finally what is the oil capacity with a new filter (1.8L). The manual says 2 7/8 quarts.
Thanks,
Doug
[email protected]
