Q45man1 »
https://forums.nicoclub.com/q45man1-u39883.html
Tue Oct 16, 2007 4:56 pm
This is the procedure to program your remote transmitter when you want to added or replaced your transmitter or there's a system malfunction:
You can program up to 4 key remote transmitters
1. Close all doors.2. Insert and remove key remote transmitter from the ignition switch more than 6 times within 10 seconds.3. indicators will flash twice.4. Insert key remote transmitter into the ignition switch and turn to ACC position.5. Press any button on first key remote transmitter to be programmed.6. Indicators will flash twice to confirm correct programming.7. Oldest key remote is now erased.
To program next key remote transmitter.1. Unlock then lock vehicle using lock/unlock switch on the driver's door control panel.2. Press any button on second key remote transmitter to be programmed.3. Indicators will flash twice to confirm correct programming.4. Oldest key remote code is now erased.5. repeat above procedure to program remaining key remote transmitters
To exit programming mode: open driver's door.
Check operation of all programmed key remote transmitters.
dealers can program these transmitters by using diagnostic equipment for a price.
