What do you call the lower light assembly on the front of a QX4? It houses the turn signal and another, clear, bulb (sorry, don't know the proper term for it). And are there instructions available on how to replace the bulbs? The clear one is out in mine.
I was able to access the back of the assembly, but not with a clear view. There is a protective cover that appears to be attached with screws (which I removed) and a couple of plastic rivets. I see there are twist-off covers for the bulbs, but when I remove the one for the clear bulb, I can't see well enough to see the proper way to remove the actual bulb.
Any help appreciated!
