I have a similar issue with my 2004 Pathfinder LE. My reason for quoting you Kompresshun is that I noticed in your profile info that we are very close geographically speaking. Do you know of any good places around Lexington/Nicholasville to get work done? My maintenance list is growing exponentially, and I do not know many places in Lexington yet (just moved from Frankfort in the last 2 years).Kompresshun wrote:You mentioned the tires have been replaced, but are you sure that you don't have a bent wheel? I had a similar issue and the tire shop didn't even check the wheel to see if it was bent, they just told me that they had a hard time balancing it. Later on I found out the wheel was bent really badly, which caused a very similar vibration on one of my previous vehicles.
Considering everything you've done, I don't see how anything else could be an issue. I assume you replaced your universal joints when the drive shafts were balanced?
Sorry for the double post. I wanted to add that I will post whatever I find with my vibration issue with my upcoming mechanic visit to this thread. These vibrations can come from anywhere and they are annoying as heck, but there is no guarantee that my fix will be your fix. Mine feels like an issue up towards the front of the car, but I occasionally feel a clunk when switching from forward to reverse or vice versa and when I let off the gas and then begin accelerating again without fully stopping so it could also just be my U-joints or even the rear differential. I'll report back here after my visit to the mechanic.nickelghandi wrote:Awesome! Thanks! I'll check them out this week.
