TriniTT »
https://forums.nicoclub.com/trinitt-u125822.html
Mon Apr 06, 2015 9:31 am
Hey all, I recently acquired a 2002 qx4 that had some issues I have been working on eliminating. As a preface, I have over a decade of extensive auto tech experience, I work for a company that does custom engine wiring harnesses so I am more than familiar with the FSM of this vehicle and how to troubleshoot technical issues in general.
I drove it recently and it seemed to be lacking in power and did not shift quite as smoothly as I would have expected. I checked the trans fluid and it was a bit low, so I added until I got a proper reading on the hot mark once it was warmed up, trans in park on a level surface. I drove it a couple of miles today and stopped to check the fluid again. To my dismay, at the first crack of the transmission dipstick tube seal on the dipstick, it exploded ATF with incredible force everywhere! I have searched high and low and cannot find anywhere that others have seen this issue. Any advice would be greatly appreciated.
I will note that I had this issue earlier, but was getting a code p0740, so I replaced the corresponding solenoid and also replaced the strainer and oring at the same time and hoped the solenoid might have been the culprit. The code is now gone, but I am still seeing the over-boiling or pressure issue from the dipstick tube. I have read other posts claim that there is a vent somewhere on the trans that should relieve any such pressure, but I cannot locate that vent anywhere and I do not see it on the FSM diagram. The car has issues not wanting to shift correctly, still has a lack of power under acceleration, and wants to stay in a specific gear even up to 5k rpms while cruising on the interstate with virtually no throttle. Eventually it will drop into a higher gear, but none of this behavior seems normal to me.
