2002 Qx4 tail light replacement questin
tomR
Can anyone help me figure out how to change the tail light bulb on the passenger side in my qx4? I cant figure out how to get the lens off and the manual is no help. It just says the lens is held on with "nuts." I can only see and access the screws in the tailgait but the front side of the lens is secured some other way. Anyone know how to access the fasteners?Thanks,Tom
cborreson
Car: 1998 QX4
Sounds like more than one guy is havin probs with this, I took mine out yesterday on my 98 and the front is held in with sprig type clips.....just pull back and try wiggling up and down,watch your paint! Should pop out. They're realy tight cause it high end sH*t that will never rattle loose.
tomR
Got it out. Was in there pretty tight but it wiggled out like you said.Thanks
