ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Fri Nov 04, 2011 8:31 am
My car a 97 QX4 does not click at the rear end, but on one occasion after doing routine PM, the clip holding the adjustment of the rear shoes came off and it did cause clicking but that noise was very noticeable and it took pulling off the hub to see that it was off and caught between the brake shoe and drum. An easy repair.
Your sound (noise) must be determined as to where it is, then what it is. The consequences of ignoring it can neither be explained nor addressed without knowing what is taking place.
Are you sure that it is in the rear axle, drive line, brakes or transmission, transfer box? Can it be a vibration as to the brake line bouncing around, the e brake too loose? Does the sound disappear if you gently tighten the e brake?
Can you place the car in 4x4 2x2, auto, etc and get differing sounds?
You are going to have to do some investigating.
