Towncivilian »
https://forums.nicoclub.com/towncivilian-u161382.html
Sun Sep 11, 2011 10:27 pm
I have heard of Fram filters causing startup rattle, among other noises. The cheapest thing to try to fix this is change the oil filter, then look into other possibilities. Oil weight, and to a lesser extent, oil brand, can have an affect as well.
The OEM filters are indeed constructed quite well, but I think Purolator PureONEs are better value for the money as their efficiency ratings are publicized, and they are constructed with metal end caps (not necessarily an issue, but personal preference - and all higher capacity/extended drain oil filters are built with metal end caps - that says something!). Regarding efficiency, I believe the PL14610 and PL14612 (the former spec'd for our vehicle, and the latter spec'd for smaller Nissan engines and is smaller in length, but otherwise identical in terms of bypass PSI, etc) are rated at 99.9% at 40 microns instead of the 99.9% at 20 micron thats the rest of the PureONE series is. I have heard of people using PL14459s on Altimas for the better efficiency rating, but the outer diameter gasket size and bypass PSI is slightly different. As to what consequences that lower efficiency rating entails, I'm not one to guess. But I digress - if you would like to discuss the finer points of oil filters, you can start a new topic.
