4xq »
https://forums.nicoclub.com/4xq-u207684.html
Sun Sep 21, 2014 9:59 pm
Ok, you've ruled out the catastrophic stuff - fluids are good, so no bad head gaskets / heads. transmission fluid is good, so your new radiator appears to be fine and I assume you know it is holding pressure. You've tried two main thermostats, and no change. Wrong symptoms for a fan clutch problem - they help cooling in stop and go / slow heavy traffic situations.
If you want to try and get the heater core hoses to fill with water, turn the heater controls to econ and crank the temperature knob up to max. That should ensure that as the engine hits normal temps the heater control valve opens and lets coolant circulate through the heater. Do this while driving so the water pump is pumping coolant pretty well. Idling may not work well.
I think you already have a couple of clues your water pump is fine. First, you got water to pump up out of the bleeder tube when you revved the engine. Second, at some point since you've had problems you have probably noticed the top of the radiator is hot. The water pump needs to pump the water to the radiator for that to happen.
Mechanically, the water pump is gear driven off the timing chain with a metal impeller pressed onto the water pump shaft. Its almost unheard of for that metal impeller to slip. Many newer cars have plastic impellers, and those can slip and cause problems in some cases.
You can check to see if the water pump works by taking off the radiator cap. You have to wait for the thermostat to open, at which time the water pump sucks coolant out of the bottom of the radiator and pushes hot coolant into the top. You should be able to see coolant flowing in if you rev the engine. May be hard to see if you are idling. Regardless, the top of the radiator will get hot.
That leaves one thing in my mind - the water control valve on the back of the engine. I think that may be where you end up.
A word of caution - don't know if you saw Canuckqx4's thread a few months back. His water control valve stuck. After about 20 or 30 minutes of idling, the coolant in the lower portion of the block boiled. The resulting steam pressure cracked his heads. So I would not leave the car idling for extended periods like that till shes fixed.
