2002 Qx4 Oil Pan Gasket
Israelpr
Car: 2002 Infiniti QX4, 6 cylinder, 2WD
I have a very small motor oil leak (1 drop every other day). It appears I need to replace the oil pan gasket (it is the gasket that has 10 screws not the one that has 2 halve moon gaskets) I guess it is also known as the "lower" pan gasket? Is this a DIY thing (provided I find the gasket) or is it something I need to take to the dealer? I'll take all the help I can get. Thanks and happy holidays!!
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
There is no actual gasket, you make your own. See EM-15 and EM-3. Be sure to use this RTV as it is specified in the FSM.
