Mikey178 »
https://forums.nicoclub.com/mikey178-u136238.html
Thu Aug 27, 2009 5:47 pm
In my opinion, I don't think it would be possible to get the sound of a g35 or fx35.
The intake would only give you a vacuum like sound. A member of this forum, slickroger, has an intake on his pathfinder and I got to see it at our first meet here in the GTA and it wasn't loud like I thought it would have been, but it did have a decent sound.
The straight pipe will definately give you a louder qx4, but I think if you choose the right muffler and do away with the resonator and bump up the pipe diameter then you should get a sound your looking for. I have a magnaflow muffler with 2.5" piping and dual out. Sounds loud and is a head turner.
It took some time to get use to the sound but it has like a growling sound when you accelarate and release the gas just before the gear whiches from 1st to 2nd.
Its not cheap tho. Id say the intake is maybe a more "wallet friendly" way to go, but ideally the exhaust will give you the most sound.
