302LVR »
https://forums.nicoclub.com/302lvr-u212864.html
Mon Feb 08, 2016 12:31 am
Hello. Guess im reviving an old thread by I'm currently having issues with the maf sensor on my 02' pathfinder 2wd. I originally scanned my CEL light and the code P1102 came up telling me the mass air was bad. I went ahead n took a chance with picking up a used maf sensor off a 3.5 maxima @my local junkyard before buying an aftermarket replacement or an expensive oem dealer sensor. After installing the sensor the car idles and drives fine and the CEL light hasnt returned ever since but i still have 1 issue. Whenever i floor the truck or go above 70% throttle i would say, the truck accelerates pretty good on low end but starts lagging above 3k rpm and feels held back and wont accelerate to higher rpm. Also, when i let off the throttle during this condition it tends to shift roughly and very delayed which it didnt do before the oem maf sensor went bad on it. So my main question is, Is this maf sensor a proper replacement for my oem truck sensor or is this what seems to be causing my truck to respond slower under hard acceleration?? I also followed a link on this thread above and read thru the Nissan ECS book to try and find answers to my issue but didnt find a concrete answer. The only thing i did try was the IDLE AIR LEARNING process to see if that makes a difference. Please let me know of any other ideas or suggestions you guys may have for this issue and thanks for the help in advanced.
