fleurys »
https://forums.nicoclub.com/fleurys-u158666.html
Tue Apr 20, 2010 12:35 pm
It would not stop it... I have read a post on another forum from a member when it actually happened.. He heard a loud crunching noise , like metal being hit in the engine for about 10 seconds then nothing.. The engine never stopped, then he could hear clicking noise on idle and no noise when he was revving it....
In any case, if one or more screws made it's way to your cylinder, then they are probably lodged in your catalytic converter. I think they are bronze or copper screws, so they are softer metals. You may want to make sure to monitor closely your oil level consumption. If your truck does not take any oil then it is safe to assume your rings are ok and the cylinder walls are not damaged... At that point the noise would probably be a valve that has bent just a bit...
in any case, you need to check these damned screws.:-).. The 3.5 engine is really a good engine, but this is probably the only really bad thing about it... I hope for you all your screws are there...then you know it's another problem and probably a smaller one..
