2002 QX4 Fog Lamp
Israelpr
Car: 2002 Infiniti QX4, 6 cylinder, 2WD
How do I remove the passenger side fog lamp assembly (not just the bulb) from my 2002 QX4? Is it a major project or is it a DIyourselfer? Thanks.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Use a cloth-covered flat blade screwdriver to pry off the black cover next to it from the fog lamp side, remove the two 10mm bolts securing the fog lamp assembly, remove the fog lamp assembly, twist out the bulb holder, and you're done.
QX4ME
Car: 02 Infiniti QX4 4WD
11 MB C300 Sports
06 Honda Odyssey
Mine is also 2002 QX4, and there are two screws holding this piece. Unscrew them, take this piece out then unscrew the 10mm (?) big screws behind this first small plastic piece.
Two small outside screws are black, same as the small plastic piece. Get close and you can tell they are there.
Towncivilian
Ah, I had no idea the QX4s had additional screws holding in the cover adjacent to the fog light. On Pathfinders it's just held in with clips.
