Yeah, -25 wasn't pleasant. The t-case was acting funny. It was engaging 4H even in auto for the first few minutes of my drive. The nav system was stuck on the initializing/loading page and the HVAC split screen would not auto hide, the overdrive would not engage for the first 5-8 miles of my 50 mile commuteRockwood wrote: ↑Tue Jan 22, 2019 1:02 amMinus 25 is pretty nippy! Have you changed out your brake fluid since you got the Q? You might have some moisture in your brake fluid - it will freeze in the fluid at 25 below. That might be why it took 20 minutes to get brakes.
I looked at the diagram you linked - there is another diagram for vehicles with production dates after 7/2001. It does not show a check valve. If you look closely, the attachment point for the vacuum line from the manifold is on the driver side of the brake booster, which should match yours. In the diagram you linked to the attachment point is on the passenger side. I think they may have put the check valve inside the brake booster.
A new booster is kind of pricey!
I re-read the FSM and it doesn't show any differences in the boosters between vehicles equipped with ASCD vs. regular cruise control. That being said, I can't seem to find the check valve.heavy hitter wrote: ↑Tue Jan 22, 2019 6:13 amTHE FSM for 2002 pathfinders definitely shows a check valve in the hose that I mentioned earlier. So I’m not sure
Given how slow the leak was, blowing air did not verify the problem. I took the hose in at work and had air blown in at 60psi, 10psi and 5 psi. All verified that the check valve operated as normal. I couldn't replicate an extremely slow leak (i.e. overnight leak) in cold temperatures.heavy hitter wrote: ↑Thu Jan 24, 2019 11:35 amDid you verify whether you could blow air in both directions through the hose with the check valve on it?
I thought they had integrated it into the booster as well. The prospect of having to spend $500 or more on a 17 year old vehicle didn't seem particularly appealing to me. So I got the hose off and felt around to find the check valve! Never seen a set up like this but I think they use a mandrel to push the check valve in while the hose is hot post molding.Rockwood wrote: ↑Sat Jan 26, 2019 4:29 pmWell I had no idea they had hidden the check valve inside the hose. I thought they had made it a part of the booster.
Looks like you are going tp see some really cold weather this week. 20 below zero is very possible. So you will get to check and see if you have really fixed it. Sounds like you are on the right path tho.
Pity I didn't catch this thread any earlier. Someone in the sedan forums had a thread trying to locate that check valve, and it seems that for the newer models they ditched the individually replaceable check valve.brickbox wrote: ↑Mon Jan 28, 2019 6:38 am...
It was down to 0F with windchill today morning and the brakes worked fine. I'll report back tomorrow and day after as well on how things go. I'm hoping I have no horror stories to tell!
I was able to verify that at 10psi and 5psi, the check valve was behaving as it should i.e. unidirectional flow. But so far, the brakes have been behaving well and I think my problem is solved. Although I'll report back how it fares over the next two days.EdBwoy wrote: ↑Mon Jan 28, 2019 10:06 amPity I didn't catch this thread any earlier. Someone in the sedan forums had a thread trying to locate that check valve, and it seems that for the newer models they ditched the individually replaceable check valve.brickbox wrote: ↑Mon Jan 28, 2019 6:38 am...
https://forums.nicoclub.com/brake-boost ... l#p6783945
Anyway, onto the test that you were doing here. Normally the check valve allows air movement away from the booster, towards the engine. If you were to blow air on a bench test, then you should observe this:
- Air can be blown away from the booster, but not towards it.
- There shouldn't be much of a restriction blowing it (especially beyond 10 psi) away from the booster. So the slow leak was either a sign of a blockage or a failed check (depending on direction).
It seems your original check valve was stuck closed/obstructed. Either way, please let us know how the replacement fares on in unfair weather.
Addendum that I've used for booster diagnostics - https://www.google.com/amp/s/m.roadkill ... oster/amp/
