2002 QX4 ABS and 4WD Lights On
Verycrisp
Car: 2014 Nissan Altima
2002 Infiniti QX4
2001 Nissan Maxima
I was wondering if these 2 lights are related. I recently got a solid abs light after starting the truck. Now after driving for about 30 minutes I get the 4wd light too. Could the 4wd light come from a bad abs sensor or do I have 2 separate problems?
blkqx4
Car: 1999 infinity qx4
How old is your alternator i had a similar issue it was alternator. Have it tested for proper charging.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Try running the self-diagnosis procedure described on page TF-28 of the factory service manual.
Verycrisp
2002 Infiniti QX4
2001 Nissan Maxima
Thanks guys. blkqx4 my alternator checks out fine. Towncivilian I followed the steps and got 17 flashes from 4wd and what looks like a 25 and 21 codes from ABS. The 17 code explains a shorted ABS signal but the ABS codes state open circuits for both front sensors. Should I replace the front 2 sensors and see if that fixes my ABS, then move to 4wd, or will the ABS fix the 4wd?
Towncivilian
Have you ever flushed the brake fluid? Also, it may be worth disconnecting the front ABS sensor connectors and giving them a thorough cleaning with electrical contact cleaner. The ABS codes are most likely causing the 4WD light to illuminate as well.
Verycrisp
2002 Infiniti QX4
2001 Nissan Maxima
When I got the truck it sat a while so I changed the calipers, and wheel cylinders and flushed the system. I'm going to check the sensors, clean the connections and test again. Hopefully I don't have to replace them.
