Towncivilian »
https://forums.nicoclub.com/towncivilian-u161382.html
Sat Jul 27, 2013 8:28 pm
I wouldn't be worried. Depending on how hot it is, my A/C doesn't work excellently either, even with circulation on, temperature at maximum cold, and at fan speed 4 (manual dial controls here). Basically if it's 90F degrees or higher and I'm idling, the air is cool but not super cold. Moving helps since there is more air flow through the A/C condenser.
The only things you can do is to clean the A/C condenser of any bugs or dirt buildup, and change the cabin air filters if they are more than two years old.
