2002 QX4 A/C
Israelpr
Car: 2002 Infiniti QX4, 6 cylinder, 2WD
Is there a need to clean the a/c evaporator on my QX4 as a preventive measure, and if so, is this something a DIYer can do?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
If you mean the evaporator which is right after the cabin air filter, you can remove the cabin filter and vacuum it out, but the presence of the cabin air filter generally keeps the evaporator free of leaves and other debris that has the potential to cause problems such as fires.
In WD21 and D21 Nissans, it is possible to remove the blower motor resistor to gain easy access to the evaporator core. This is what possibly could be hiding:
Israelpr
Thanks a million, your advice and insight is always greatly appreciated. Have a GREAT new year!
