nickelghandi wrote: ↑Thu Mar 01, 2018 11:15 am
Thanks for the link to my thread!
The crossbars are actually pretty easy to remove. I did that on my 1999.5 Pathfinder back in the day to try to save some MPG. I gained maybe 1 MPG out of it and then had to put them back when I wanted to throw a canoe on the roof.
For the immediate question:
I think you can just remove the two front end caps and then all of the roof rack hardware will slide out of the holding brackets. It is either a T25 or T30 star bolt.
As far as picking up some MPG the best thing I did was slow down. Cruising along at 60-65 mph I can get 20 MPG out of my 2004 Pathfinder with larger tires, grille guard, and a 2.5" lift. I do have a pretty free flowing exhaust, but I seriously doubt that is making any difference except maybe at WOT.
I took mine from 11 city and about 15 highway to 16 city and 20+ highway just by timing lights and stops. I used a scangauge and monitored my driving habits as I went. Passing, going up hills, changing lanes, etc. will suck down gas really fast. Hyper-miling might not make much difference in terms of actual mile per gallon gains, but that is a 25% increase for me. I haven't heard of many other vehicles that can claim a 25% increase to their fuel economy.
Some front or side skirts might help you a bit on that drag. It would increase the frontal exposure, but maybe smooth it out to help it glide a bit better through the air. The more it looks like a boat, the better MPG you will have.
Lighter wheels and tires will make a difference too. On the highway larger diameter tires may actually be helpful because you can be traveling the same speed at a lower RPM. If it is hilly then no, but flat roads it is possible.
You can unplug the injectors and just run 4 cylinders in v-configuration. You will throw a ton of codes and possibly fry your ECU or burn pistons/walls, but it might be interesting to see what kind of MPG gains you could get.
Eliminating as much weight as possible would make a difference as well. Strip out the rear seats, follow my roof rack removal guide and just take everything out of the vehicle. Pull out the heavy carpet and sound deadening insulation. Remove your running boards if you have them. Remove your spare tire and tire carrier hardware. Heck, delete your muffler and resonators and run a pipe straight back from the cat or bend it into a side exit exhaust. It will be lighter and also free up the exhaust some. Remove the towing kit if applicable. It depends on how far you are willing to go and how much noise and misery you will put up with to achieve your goal.
Manual locking hubs are supposed to make a difference if you have 4WD. Or if you never use the 4WD delete that entire system freeing up weight and eliminating the drag it has on your drive train.
Premium fuel make a difference in my 2004 Pathfinder. The VQ needs high compression to put out enough power to push the vehicle.
Like I said I can push 20+ MPG highway now and I have roof racks and other aerodynamic drags as well as a slight gear ratio deficit with the larger tires. I will drive 65 and people can get mad if they want. As long as you aren't holding the left lane or something they have no right to get mad. I live in KY and people are usually pretty nice on the roads here, but no matter where you live or how fast or slow you go, there will always be someone that wants to go faster or slower than you.
