2002 Q45 wiring harness removal
F50Enthusiast
Car: 2002 Infiniti Q45
How would you go about removing this wiring harness lead going into the firewall(imgur link below)? 2002 Q45
A mechanic friend of mine said you should be able to just pull it out and plug it back into the firewall afterwards. Or do you need to disconnect it from the glove box area inside the car?
https://imgur.com/gallery/zmICRa9
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
On Nissan products, that type of firewall grommet often has a plastic backing plate with pawls that need to be relieved from the inside.
F50Enthusiast
VStar650CL wrote:
Tue Dec 20, 2022 7:26 pm
Thanks for the insight
