2002 Q45_Water trapped??
longlivetitus
Car: 2002 Infiniti Q45 Sport
2007 Infiniti FX45
I just noticed something odd this morning when I was backing out from my garage to the drive way.
I can hear water swishing as I shift to reverse..doesn't last long and doesn't always happen?
Has anyone had this happen to them....rain water?
Longlivetitus
2002 Q45 Sport
djwarner
Car: 1971 240Z Series I
2006 350Z
Can you determine where the sound is coming from? I'd check for trash, leaves, etc blocking drainage from around the trunk seal and around the hood/windshield interface.
I would say to check the a/c evaporator coil drainage, but then I noticed you're in northern CA and you probably aren't using the a/c this time of year.
And for the record, I don't have your problem and it isn't normal for the breed.
longlivetitus
2007 Infiniti FX45
Greetings djwarner,
The 'water swishing' sound is coming from behind the dash area? Yes, I haven't used my a/c in the past couple months.
Where is the coil drainage located?
djwarner
2006 350Z
I haven't the slightest idea, never had to look for it. Surely someone will give the link for the FSM, unfortunately, I don't have it at hand.
Q451990
djwarner wrote:Surely someone will give the link for the FSM, unfortunately, I don't have it at hand.
www.nicoclub.com/FSM/
:biggrin:
