ahmed_wasim »
https://forums.nicoclub.com/ahmed-wasim-u9763.html
Tue Jun 26, 2007 3:51 pm
Hi,
I noticed the following two things on the 2002 Q45 that I bought recently.
1. Steering vibrates at 65 plus miles. It also vibrates when you brake at high speeds. From reading the prior topics it looks like a balancing issue.
2. Today I noticed a noise from engine compartment. It sounded like the fan is spinning at really high speed. The growl increases if you push the pedal. Can it be the idler pully problem.
Regards,Wasim.
