qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Sat Feb 26, 2011 11:50 am
Are you doing a simple drain and fill using the drain plug on bottom of transmission? If so you will only get about 3-5 quarts of ATF drain out- measure amount drained in a graduated jug {old gallon size milk/water jugs that you have marked in 1 quart lines} and refill with same amount of new ATF. If this procedure has never been done before, or it was a long time ago, never hurts to drain/refill and drive 5 miles to mix new atf with old and then repeat with a 2nd drain/fill, possibly even a third/forth drain/fill if the drained atf does not look like new.
