Zoltan11 »
https://forums.nicoclub.com/zoltan11-u167230.html
Mon Nov 05, 2012 1:28 am
Hey guys,
New to the Q forum, but been with the A33 forum for a while.
So I just picked up a 02 Q with 165k it has a high pressure line power steering leak, and the power steering system as a whole makes a lot of noise. The power steering pump was replaced 5k ago. I'm wondering why the power steering whines so much being brand new? And also if the leak in the high pressure line would cause the steering to stick a little during slow tight turns?
The matainance records show that the serpentine belt was replace not to long ago as we'll as a couple tensioners. When the car is cold and running some pulleys down low on the belt config whine a little at idle. Goes away after warming up.
Any advise on known power steering problems would be appreciated.
