Postby
kevindanielk »
https://forums.nicoclub.com/kevindanielk-u42212.htmlSun Mar 25, 2012 11:21 pm
If the valve cover(cam cover) gaskets are starting to leak, oil will drip down onto the exhaust manifold and burn off, giving you that telltale smell. Mine started to leak right after I switched over to synthetic oil. Check those cover gaskets.
Postby
djwarner »
https://forums.nicoclub.com/djwarner-u152452.htmlMon Mar 26, 2012 6:41 am
I've had a love/hate relationship with Mobil 1 for the last ten years for just this reason. Can't say I've had this problem with other synthetics. That being said, Mobil 1 has worked just fine in my '02 Q.
Postby
qship96 »
https://forums.nicoclub.com/qship96-u3104.htmlMon Mar 26, 2012 1:05 pm
Synthetic oil {even "fake"synthetic oil like most use without knowing it} does not CAUSE oil leaks,it MAY do some cleaning and remove thick sludged oil build up that kept faulty seals from seeping,but it does not CAUSE leaks.
