2002 Q45 PO 0380 ec
acpower5
Car: 2002 infinitti Q45
Engine code of PO 0380 glow plug/heater circuit A malfunction. Starts fine,runs fine but can tell it is missing when idling. Any help? Don't even know what glow plugs are...
djwarner
Car: 1971 240Z Series I
2006 350Z
Are you sure it is 380, I didn't find a listing for this code on
http://engine-codes.com/make/infiniti/1
P0308 is a misfire on cylinder #8 makes more sense per your trouble description.
ddsmith60
Car: 2000 Q45t
I agree with DJ. Glow plugs are diesel engine stuff. If it is P308. You may want to check #8 plug and play coil swap games to figure out if it is a coil issue if the spark plug doesn't fix it.
