carnut »
https://forums.nicoclub.com/carnut-u22856.html
Tue Nov 21, 2006 1:01 pm
I'm back and here are the observations after pokeing around with a stethoscope:
1. The noise is coming from the back top of the engine, confirming the valves diagnosis and statements that shims are likely needed in the back2. After several minutes of idling the noise almost goes away and is replaced with a quiet ticking. Revving the engine up brings back some of the noise. (This is opposite to what factory manual says, which indicates noise after warm up to be likely associated with valves. But the manual could be wrong). 3. Manual provides description of the shim changes, but using some 2 Nissan tools without removing the camshafts. Hopefully faster than the camshaft removal method mentioned. BTW, xerexabante, just curious, is your F50 also a Q45 or one of the other trims not typically available in US (Cima, President etc?)4. I'm still dissapointed with Nissan for not using HLAs - I realize that the metal shims allow a few more HP and higher revving (there are kits available for e.g. Porsche 911 to convert newer hydraulic lifters to older shim designes to get those few extra HP, but this is a different application - Q45 is a sporty limo and I would rather give up a few HP for a convenience of not dealing with valves out of adjustments)
5. And now SURPRISE: I've just called my local Inifiniti dealer now to ask for a price of valve adjustments, and guess the answer? They don't do it!!! They don't do the engine flush either!!! The consultant said that if there is anything wrong inside the engine they just replace it (at $8000, as the warranty expired last year). But he offered me an appointment for the Factory Service (btw, the basic one, which is a mineral Quaker State oil and filter change and the ususal inspection is on special at $196.88 plus tax, regular $533 plus tax - are those great prices or what? I can do the same faster at home for about $20 in parts)
6. So I'll skip the visit to the dealer and will start thicker oil experiments. BTW, has anyone adjusted valves on those engine already?
thx
