sam111sam »
https://forums.nicoclub.com/sam111sam-u227750.html
Wed Nov 20, 2013 6:48 am
I'm writting this post for the benefit of any one who owns an Infiniti Q45 2002-2006
Well, I had the same problem TWICE
The car would not start from the first time, it only clicks as if the battery is flat. It has nothing to do with the battery or the cables.. It is a TYPICAL problem in the Infiniti starter. The dealer knew it right away.
The problem started when the car was only 30k miles but was very rare It became more persistent at 60k Miles, so I replaced the starter motor with a used one from ebay ($60)
Now at 100k miles, I have the same problem again. The dealer does not sell the seloniod as a separate part, only the whole starter motor assembly at $400. So I will either buy again another used one from ebay ($60-80), or may be Denso for $180 from Amazon.
I love this car, it has been very nice car
Three other typical problems of Infiniti Q45 2002-2006
1) The engine can stop suddenly with no warnings , but it would start again after sometime and runs well for a week or two. Then it happens again. This is your Cam and Crank shaft sensors failing to send the signal to the car control unit. There is a safty recall on this DO IT
2) The Airbag light would come on indicating a no communication with the car control unit. Relacing the air bag will not help. replacing the seat belt per-tensioner will not help. The dealer replaced lots of parts in 2004/5 and the light comes on again. At the end they found the loose connection inside the seat that would momentarily discount while driving on a bumpy road. A fault reset will work for few week, till it happens again. The permanent solution is find that loose connector and solder it. It did work for me and no fault for 5 yrs , now I'm back to the same problem. I will just reset it when it comes on (find the airbag reset procedure on Youtube )
I read in one of the forums that the Airbag light problem has something to do with the failing starter motor, but I can not find any logical link to support this view
3) This is more serious problem. The car would lose engine oil at a high rate. Again this is a common problem in 2002-2004 models. Infiniti would open the engine and replace the rings. Very big and expensive job. I have done it at 35k miles. Now at 100k miles it is coming back but to much less extent. I lose one quart every 3000 miles while normally I would only lose 1/2 quart. If you do the engine compression test it would show good result (90%).
The above problems are common, you can read about them in the forums
If you suffer from any of these symptoms, do not break your head
Thanks God for these forums where kind people like you guys share experience's this has saved me 1000's of $$ and so many hours over the year
Finally, if you think Infiniti is not reliable, TRY a BMW 7 Series. Then you will appreciate Japanese quality. Over the past 20 yrs, I have owned so many cars in my household including 4 BMW's (5, 6, 7) , 3 Chevrolet, 3 Honda's (CRV, Perlude, Accord, Legend) , 1 Toyota (landCruiser) and 1 Lexus LX470, 3 Infiniti's . I can tell you that the Honda and the Lexus were the best, followed very closely by Infinity which offer very good value for money.
At the end I just appeal to anyone who would benefit from the information above to PLEASE SHARE your experience and the ultimate solution of the problem at the end.. You will spend less than one hour doing this, but so many people will benefit.
