Look for me other post - I have a video of how to get the lites out so you could get to ballast. Pretty ez stuff.
http://www.viddler.com/explore/rashid11/videos/10/
Now, if your ballasts are dead (mine showed a short when tested with a meter, across the 12V input), you will have 2 options:
- settle for a stealership repair- DIY (what I did)
Stealership will absolutely rape you. 2 ballasts + labor + 2 D2S (they will likely force you into replacing the bulbs too to honor ballast wty) might set you back north of $2000. Way north.
I bought newer model ballast (all/most of new Infinitis and Nissans use the new, unified ballast) off Ebay. Expect to pay about $60. You'd need to drill the HL assy to let the ballast wire in, but the rest is very easy.
Again - look @ me video
And before ordering ANYTHING, lookie here:
http://www.nicoclub.com/FSM/Q4...t.pdf
LT-9 has schematic. The only thing _common_ to both LO beams is the Headlamp relay-1 - make sure it works. Ea low beam has its own fuse ... 15A if I remember correctly - I show in me video where it is, check those too.
To test the relay, you can test the coil, see if the control signal gets to the relay, etc.
Modified by rashid11 at 6:50 AM 5/1/2009
