2002 Q45 Handling ?
bsshoomez
just took my new Q for the longest ride since ive owned and it is good execpt that the rear or the car seemed llike a steam boat with a lot of weight in the back.
like noise when I hit breakes & the handling on curves really sucked ***.
BTW i still have warranty on the Q so let me know what I need to tell the dealer to replace/check
What wheels/tires are you running?
bsshoomez
stock tires/rims
Q45tech
What does a warranty have to do with handling? All the bushings and rubber things are not really covered as to changes or wear. Same with shocks --- just covered if they leak, not if they don't perform as brand new.
Same with tires, they are not covered for changes in hardness of compound.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
bsshoomez wrote:1.) just took my new Q for the longest ride since ive owned and
2.) it is good execpt that the rear or the car seemed llike a steam boat with a lot of weight in the back.
3.) like noise when I hit breakes & the handling on curves really sucked ***.
4.) BTW i still have warranty on the Q so let me know what I need to tell the dealer to replace/check
1.) Around the block, around the country? Can't tell from your description.
2.) What setting was the suspension on? How much weight was in the trunk? Any rear seat passengers? Tire pressures?
3.) What did the noise sound like, and why did you like it?
4.) Maybe a four wheel alignment? When was the last one? Tire rotation? Tire flip? Dealer won't cover wear and tear.
Owner must maintain beyond factory minimum specifications for extended performance beyond warranty period expiration..
Modified by maxnix at 6:44 AM 6/27/2005
Q45tech
Handling is 95% tires and 5% suspension [assumming shocks and bushings plus alignment are as new------spot on in the EXACT middle of range].
bsshoomez
It was a 200 mi hike to the rural part of MD - which had mountains and high terrain like that.
Suspension? well i dont have the sports so it was stock mode i guess. About 200 lbs of luggage and 2 guys in the back of the car...I dont think its that much but the two weighted about 150 each. Tire Pressure on the computer was about 38 psi - 40 psi.
Noise was almost like grind against something - cant describe it but it likes rubbing two peices of pastic together.
I jus bought the car so i dont know but i dont think it was the alignment. Dont know any of the details of the last work done on the car.
I called my dealer and told him about what the problem was and i'm still waiting on him to call me. I'll post up w/e he says...I am getting the rotors done as well as the rear shade b/c its all jacked up. All under warranty... =-)
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Under warranty, so less than 60K miles, I presume. A little soon for shocks to be worn.
Think the front wheel was hitting the fender well liner?
Have your dealer supply you with a print out of the dealer performed service history.
DAEDALUS
Car: 1990 Infiniti Q45
I assume too that it's not the active suspension.
Anyone hear anything about the longevity of the Bose active systems? I'm considering a 2002 for my longer commute starting in a couple months.
I thought the Bose system was still in development stages?
DAEDALUS
Could be. I'm only going off what I thought I read before the 2002s came out. In one online article I read the journalist rode in a modified LS400. So what's the word on them for logevity? I think it's only active damping, no active rebound like the 1st gens.
Jason B
Car: Infiniti Q45
Well, #1, you with the luggage and two guys in the back, that's 500 pounds! That's the reason right there. It was probably riding on the bump stops.
Do you have the stock 17's or 18's.
350zQ45a
Car: 350Z, Q45A
The 02+ isn't really known for it's sports car handling, espically the non sport/base model.
