2002 Q45 Factory Options List
SonzofGod
Car: 2002 Infiniti Q45
The owners manual really doesnt do a thorough job of explaining everything that is on the Q. Is there a website somewhere that lists all the factory options that were available or standard on the Q45 in 2002. I am also interested in finding out about things like the integrated cell phone antenna, if my car has the intelligent cruise conrtol system, etc.
Just looking for a very informative site for detailed Q45 knowledge (other than this one ofcourse)
Thanks,Nick
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The best place to start is the FSM...
Heres a list of the factory options on a 2002 Q45. let me know if youneed anything else.
Brakes 4-wheel vented discs:
* 11.4" x 1.1" front rotors * 11.5" x 0.6" rear rotors 4-wheel 4-channel ABS with Electronic Brake force Distribution Brake-assist system
Steering Electronically controlled vehicle-speed-sensitive power rack-and-pinionTurns (lock to lock): 3.3Turning circle (curb-to-curb) 36.1 feet Suspension 4-wheel independent suspension:
* Front strut with stabilizer bar * Rear multi-link coil spring with stabilizer bar Front strut tower bracing Available active damping suspension with driver-selectable sport model
Wheels and Tires 6-spoke 7.5 x 17" aluminum-alloy wheels with P225/55VR17 performance tiresAvailable 8-spoke 7.5" x 18" aluminum-alloy wheels with P245/45VR18 performance tiresAvailable run-flat tires for 17-inch alloy wheels (fall 2001)Available full-size spare tire with matching alloy wheelTire pressure monitoring system Dimensions Wheelbase: 113.0 inchesOverall length: 199.6 inchesOverall width: 72.6 inchesOverall height: 58.7 inchesTread width front/rear: 62.2"/61.4"Head room front/rear: 38.4"/36.4"Leg room front/rear: 44.0"/37.3"Shoulder room front/rear: 58.2"/57.2"Hip room front/rear: 55.9"/58.0" Capacitiesand Weights Interior volume: 102.1 cubic feetCargo volume (with temporary spare tire) 13.7 cubic feetCargo volume (with full-size spare tire) 13.6 cubic feetFuel capacity: 21.4 gallonsCurb weight: 3801 lbsWeight distribution front/rear: 56%/44% Fuel Economy City/Hwy: 17/25 mpg Engine 4.5-liter, 32-valve, DOHC aluminum-alloy V8340 horsepower @ 6,400 RPM333 ft-lbs of torque @ 4,000 RPM10.5:1 compression ratioLightweight molybdenum-coated pistonsContinuously Variable Valve Timing ControlTitanium intake and exhaust valvesElectronically controlled variable induction systemDirect ignition system with platinum-tipped spark plugsElectronically controlled throttle chamberSequential multi-point fuel injectionElectronically controlled high-capacity mufflerDual-flow cooling system with hydraulic-driven fan Mechanical Features 4.5-liter, 340 horsepower 32 valve DOHC V8Electronically controlled 5-speed automatic transmission with manual shiftTraction Control4-wheel vented disc brakes with Electronic Brake force Distribution and break assist4-wheel independent suspension with front and rear stabilizer bars17-inch aluminum-alloy with V-rated performance tires Exterior features Multi-lens HID xenon headlights with auto-off featurePower glass sunroof with one touch open/close featureUV-reducing glassVehicle-speed-sensing intermittent wipersDual heated power outside mirrors with two-position memoryAutomatic reverse tilt-down mirrors (rearview and driver's only)Automatic dimming outside mirrors (rearview and driver's only)Side turn signals integrated in outside mirrorsBody-color door handles with chrome accents Interior seating and trim features Sojourner leather-appointed interior10-way power driver seat with adjustable lumbar support8-way power passenger seat2-postion driver's seatDriver entry/exit assistGenuine bird's-eye maple wood accentsLeather and bird's-eye maple steering wheelFront and rear carpeted floor mats Comfort and convenience features Dual-zone Automatic Temperature Control with auto-intake systemIn-cabin microfiltration systemOutside ambient temperature displayCruise controlRear air-condition and heating ventsPower tilt/telescopic steering column with 2-position memoryPower windows with auto up/down featureRetained accessory power for windows and power sunroofHomeLink® Universal Transceiver with rolling code featurePower trunk and fuel-door release Bose® audio system features 8 speakers, including one 12-inch Bose Nd wooferBose AudioPilot™ noise-compensation technologySteering-wheel-mounted audio controlsRear window in-glass diversity antenna systemVoice recognition that operates climate control, audio, and optional navigation system Safety Dual-stage front supplemental air bagsFront seat supplemental air bagsSupplemental side curtain side-impact air bag for front and rear passengersFront seat active head restraints3-point seat belts in all seating positionsFront seat belts with pretensioners and load limitersLATCH system (Lower Anchors and Tether for Children)First-aid kitEmergency inside trunk release Transmission Electronically controlled 5-speed automatic overdriveGated console shifter with manual shift modeElectronic real-time feedback with learning algorithm
DuDro
Car: 2003 Q45
It's easy to tell whether you have the ICC (Intelligent Cruise Control) system. Just take a look at your speedometer. If it looks like this...
Then you have it!
Modified by DuDro at 3:21 PM 4/12/2006
SonzofGod
Yes, that helps. Thanks alot for the list! I do have some questions about some of the items but I will get to those later.
One though was the cabin filter...is this replaceable by me? How do I know if I for sure have one, where is it located?
I dont have the ICC. Is this an option that can be added? I dont think I want to pay for cause its probably too high!
Thanks,Nick
elwesso
2007 BMW M Coupe
SonzofGod wrote:Yes, that helps. Thanks alot for the list! I do have some questions about some of the items but I will get to those later.
1. One though was the cabin filter...is this replaceable by me? How do I know if I for sure have one, where is it located?
2. I dont have the ICC. Is this an option that can be added? I dont think I want to pay for cause its probably too high!
Thanks,Nick
1. Yes you can replace and its quite simple. I will refer to F50 guys for that diagnosis, however it should be fairly easy (less than an hour).2. NO i doubt this would be easily added. likely would cost a lot more to add it correctly than to buy a car with it already.
DuDro
Car: 2003 Q45
SonzofGod wrote:One though was the cabin filter...is this replaceable by me? How do I know if I for sure have one, where is it located?
Here you go...
To replace the filter:
To remove the glovebox to get to the filter:
SonzofGod
Sweet. I will print that out.
I did find this link that seems to have ALOT of info on factory options....
http://www.carseverything.com/.../1337/
I didnt know the Q had a 12 inch woofer....
thanks guys!
SonzofGod
Hey DuDro did that come from the FSM?
If so it looks like I should probably get one... would you recommend going here
http://www.nissan-techinfo.com/infiniti/
and saving the PDF and then printing it out? I certainly dont want to get the crap CD they are selling on eBay. I am looking for an official Factory Service Manual for the 2002 Q45....
Sorry one other Q, does the FSM have TSB's in them?
Thanks,Nicknew 02 Q owner
elwesso
2007 BMW M Coupe
http://www.phatg20.net/
You can get FSM from there.
DuDro
Car: 2003 Q45
The FSM does not have the TSBs. Go the following link for the TSBs...
http://www.infinitihelp.com/In...1.htm
And go to this link for some good information on your car...
http://www.infinitihelp.com/In...n.htm
Check out the link that elwesso posted. That is where I downloaded the FSM. It's a large file so be warned...
SonzofGod
Thanks guys, I am downloading the manual now. I have 1.5 mbps connection so not too bad
I am hoping all my other questions will be answered in the FSM. Loving the car! I had a 97 max for 5 years. This is quite the upgrade.
later,Nick
mcrews
Car: 2002 Q45 Sport
Elwesso.....thanks for the Phat2go link for downloading FSM....needless to say you saved me $180!!!!!! (i donated 30) now I can buy
Mark
