2002 Q45 --Clicking"ish"/Popping noise coming from front of car
ahmed_wasim
Car: 95 Q45
maxnix wrote:A lot of wierdness going on in tghie thread. Unless you are driving in a salt bath, don't see why all this would be necessary. Broken springs are rare.
I once went over a huge bump on the road. That may be the cause of it. Or it may be the issue with F50s.
dan b
Car: 1994 infiniti q45
I replaced the struts. with tokicos. I did look at the insulators one on the drivers side might have slipped a little. Ill try to slip it back around. Thanks a lot u guys are very helpful.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
dan b wrote:I replaced the struts. with tokicos. I did look at the insulators one on the drivers side might have slipped a little. Ill try to slip it back around.
If you mean the integrated bump stops and gaiters, they are always replaced with the dampers.
seldomseen
Car: '12 Nissan Altima Coupe SR 3.5
'15 Lexus GS350 F Sport
If you already haven't just have the Infiniti dealership inspect your Q to see what the problem is.
dan b
i FIXED MY PROBLEM I HAD TO REPLACE MY RACK & PINION TWICE AND OVER TIGHTENED THE SWAY BAR CONNECTOR TO THE FRAME. THE BOLT FELL OUT ON ONE SIDE I FOUND IT BY UN BOLTING THE STRUT AT THE TOP PULLING OFF THE TIRE AND JACKING THE CAR UP AND SHAKING THE HUB ASSEMBLY. SAW THE PROBLEM RIGHT OFF I PUT IN A SAE STANDARD THREAD 3\4 BOLT WITH RED LOCK TIGHT TOOK CARE OF MY PROBLEM THANK YOU ALL FOR YOUR HELP.
