mtyler7807 »
https://forums.nicoclub.com/mtyler7807-u291737.html
Mon Aug 19, 2019 5:30 pm
The guy I brought it from thought it was a junker, he was wrong. It had a horrible miss and wouuld barely stay started. Every light you think about except transmission lights were on.
check engine, abs, slip, vdc, traction, seatbelt srs,
But the engine temp was fine.
I call it the amazon/ebay car.
The car needed plugs and wires - installed them - ngk and aftermarket plugs/coils, they leave me with a p1320 but I will live with it.
new crank and cam sensor
new vvt solenoids bank 1 and 2. get them from jc whitney. $30 for driverside
pretty much all sensors with name brand sensors.
new abs sensors in fr and fl
used petionomitor for seat beat
No more codes and the car runs like dream. I tried everything to remove the abs codes. Save yourself some time get the abs sensors.
The creader crp129x obd2 scanner works well with the 2002 q45
It reads brake codes and resets them.
I have worked on it for a whole let me know if you need any help. I have tracked down a few things. If you cant get rid of the srs code for drive side petitionmeter, pull the seat belt all the way out and let it go and reset the code.
