xerexabante »
https://forums.nicoclub.com/xerexabante-u48008.html
Sat Jun 23, 2007 10:50 am
2002 Infiniti Q45 V8-4.5L (VK45DE) Vehicle Level Restraint Systems Air Bag Systems Testing and Inspection Diagnostic Procedures Procedure 5 Trouble Diagnosis Without CONSULT Scan Tool Procedure 5 Trouble Diagnosis Without CONSULT Scan Tool Notes Trouble Diagnosiswithout CONSULT-II.
DIAGNOSTIC PROCEDURE 5
CAUTION: SRS will not enter diagnosis mode if no malfunction is detected in user mode.
Turn ignition switch "ON". After "AIR BAG" warning lamp lights for 7 seconds , turn ignition switch "OFF" within 1 seconds . Wait more than 3 seconds . Repeat the steps 1 to 2 two times. Turn ignition switch ON". Compare the number of flashes to Air Bag Warning Lamp Flash Code. Turn the ignition switch OFF, and disconnect the battery ground terminal.Warning Lamp Flash Code Chart Part 1
