2002 Q grey smoke in the morning
ahmed_wasim
Car: 95 Q45
When the car starts in the morning it gives grey smoke for a few seconds (2-3). The car has 98k miles (168k km) on it. Is it due to the oil consumption these engines do or is it something to worry about? Anyone else has noticed this.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Are you sure it is not steam (water vapor)?
If it disappears immediately and doesn't persist or smell, it probably is.
shrapnail
Car: 03 SE-R, 89 240sx
^points yeah..
Other concern would be oil burning off from "settling" in the night or running a bit to rich upon startup.
What would cause the engine to run rich initially could be a # of things, but it might be due to the cold engine needing to warm up and "seal up" to get to it's normal level of performance.
But these are stretches, above poster is the thing to check first.
ahmed_wasim
Car: 95 Q45
Its not vapor. My friend was driving the car and I noticed the smoke when he started the car and again (for 2-3 seconds) when he switched from reverse to D.
xerexabante
Car: '02 Infiniti Q45
'02 Nissan Maxima SE
I had the same problem, but when I changed my oil to Mobil Syn. The problem was resolved, I don't jave thet issue anymore and the oil consumption is gone.
Skibane
Car: 2000 Q45 AE 110K
A couple of suggestions:
1. Make sure the crankcase isn't overfilled.
2. Avoid heavy-throttle, high-RPM operation right before you put 'er to bed for the night.
