First of all, I couldn't find a pathfinder forum, sorry if this is in the wrong place.
I just bought a 2002 Pathfinder 185,000 miles and it has 2 bad oil leaks. Just sitting cold, the engine leaked about 60ml overnight in 2 spots.
The one in the rear seems to be forming between the transmission (automatic) and the engine or the aluminum oil pan. This makes me think the leak is coming from the rear main seal or the upper oil pan gasket. I've attached a picture where you can see the bead of oil. If you look closely (on the right, next to the bolt) you can see a second bead. Above those beads is completely dry.
The other leak in the front, seems to be forming in what I think is the oil cooler. Whatever that component is, it's connected to the aluminum oil pan right next to the oil filter. I've attached a picture of this one too. This picture is looking up from the front. The area where this component connects to the oil pan seems clean as well. I think this device itself might need to be replaced.
My thought was to change the upper oil pan gasket and the rear main seal while in there. I was curious to get a quote and went to a mechanic that I was told was very honest and good. He told me that a car with this age and mileage, I shouldn't fix it. He said that the crankshaft moves whenever I push and release the throttle and within a few months, the leak would come back.
My questions are:
1. Do you think the upper oil pan gasket and rear main seal are the likely causes of the leaks?
2. What is that device in the picture that is towards the passenger side of the oil filter?
3. Do you think I should replace that device?
4. Do you think this mechanic is right that it would leak again really quick due to engine movement?
5. If that mechanic is right, is there anything I can do to fix this?
I'm not looking to give up on this car. I would like to fix it up and have it for several years.
Thanks.
Rear:
Front:
