2002 Pathfinder Window Master Switch
Jschiola
Car: 02 Pathfinder
Hello,
On my 2002 Pathfinder SE, the windows will not roll up or down. The master switch doesn't work, and neither do the door window switches. The fuse is fine and the door jamb switch is fine. The locks work as they should.
Is there a power window relay on these?
What else could be the problem?
Thank you for the help.
sstroudwku
Car: 2013 F150 EcoBoost 4x4 - BlueJean Blue
2014 Pathfinder
If your master switch fails, it can effect the rest of the switches. I'd suggest replacing the master switch.
Switch Doctor
Car: 87 Saab SPG
You can get it here and if it isn't the issue it can be returned within 30 days. Most places wont let you return electrical parts. http://www.switchdoctor.net/nissan-path ... 2-oem.html
