2002 Pathfinder Sunroof Problem =(
Micpathfinder
Car: 2002 pathfinder LE
SO randomly my sunroof stopped working today. Neither switch does anything. I don't hear any noise and no lights dim when I activate the switch. I looked in the FSM and it seems that the same relay (M23) and circuit breaker(M145) that is used for the sunroof, is used for the power windows as well. As the power door windows work, should I assume its a bad power sunroof motor?
Thanks
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
SO did you check the sunroof fuse yet?
If not, it should be a 7.5A fuse , #11 in fuse block
Micpathfinder
Yes, Fuse has been checked and is fine. I wish that was the answer...=)
