lucyx4 »
https://forums.nicoclub.com/lucyx4-u241156.html
Tue Nov 04, 2014 7:31 am
Does anyone happen to know how different the 4WD systems are between the QX4 and Pathfinder?
My Pathfinder has part-time 4WD with a manual transfer case, whereas my QX4 has all-mode 4WD, with an electronic knob on the console to actuate it instead of the lever from the transfer case. I have decided to swap transmissions between the two cars, since it looks to be a lot easier than swapping all the features I wanted to have in the Pathfinder. Thus, I'll be taking the manual transmission out of the Pathfinder and putting it into the QX4, and I'm wondering if the driveshafts would be different lengths due to the different transfer cases, as well as potentially having different axle ratios between the two cars, and of course wiring and control modules for the transfer cases (along with the ECU, which I will also swap).
Any help or advice would be greatly appreciated.
