dohcser »
https://forums.nicoclub.com/dohcser-u229856.html
Wed May 28, 2014 2:24 pm
Originally I was getting the Errors below:
P1140 - Camshaft Sensor
P0140 - O2 Sensor (Bank1 Sensor 2)
I replace both sensors and the codes went away and now P0171 is present. I cleaned the MAF sensor with the appropriate cleaner, changed the air filter and needed new plugs so changed those also, I cleared the codes but it keeps coming back.
This code is for Bank 1 so I don't think the throttle body gasket or MAF or anything along those lines would be wrong otherwise I would have an issue on both Bank1 and 2, but I am only getting this on Bank 1. Can anyone help me troubleshoot this issue. I do have Torque Pro so I can pull measurements if needed on the sensors.
