Hello. Im currently having issues with my truck not starting. It was working fine one day n the next day i cranked her up to go somewhere it wouldnt start n i didnt hear the fuel pump priming. First thing i did was check all my fuses, relays, etc, and checked at fuel pump harness to see if i was receiving power which i was. Since i had power at the plug but didnt hear the pump prime when turning on ACC i jumped to conclusion that it was a bad fuel pump n removed current pump n installed a new one. When both fuel pumps were in my hand, and out of the tank, i tested them both to see if they were working with 12v from the battery directly and they were. I also checked fuel filter n fuel pump return line to make sure they weren't clogged n everything was good. I put everything back together assuming the truck should now start n i still have the same issue
, I don't hear the fuel pump prime yet im receiving signal at the pump harness. Lastly, i read in some other post or forum that it might be a bad CRANKSHAFT POSITION SENSOR but im not sure n would like some feedback from anybody who might have had this problem before. The last test i performed was remove coil pack n plug from cylinder #3 n test for spark and i'm not receiving any spark. So in the end, do u guys/gals think this may be a bad crank pos. sensor or something more?? Also, is there a relay for the ECU/ECM that might have gone bad and will this cause this problem as well?? Once again, thanks for any feedback in advanced.
