nickelghandi »
https://forums.nicoclub.com/nickelghandi-u215217.html
Thu Mar 15, 2018 6:12 am
You are pretty much limited to those two brands. I don't know about Gabriel because I have never used them, but I can say that in my experience, Monroe anything is just terrible. Others may like their products, but I hate them.
Compressing the springs really isn't too bad. I like the compressors that sit on the outside of the springs. If you are all stock with no lift then it shouldn't take much compression to get them to fit. Then reinstalling them is pretty easy if you unbolt some stuff nearby to gain clearance. You can pretty much look at the area with the wheel off and see what needs to come out to make room. You can loosely attach the strut with the 3 nuts on top and then seat it on the knuckle. Pry it into place and hold it with a bolt. Reattach anything you removed for clearance and then torque everything to spec. Tighten your top 3 nuts and you are done.
I installed KYBs up front with a 2" lift and only needed the compressors to get the springs low enough to bolt on the top mount. It helps to have a friend or an upside down bucket to hold the hub assembly to keep from binding or dislodging your CV axles. I did this again when I replaced my OEM springs with Moog springs which although included no extra lift, were stiffer than the worn out OEM.
Honestly, when I took off the top mount, I didn't even use the compressors. I know it isn't the safest way of doing it but there is hardly any compression when that nut is nearly removed. The mount shifted slightly upon removal, but it didn't become a missile as the spring was already almost completely decompressed.
Good luck if you decide to do it yourself. I am pretty sure there is a write up somewhere on here for it.
