lali707 wrote:I am having the same signature for overheating on my 2003 qx4. Replaced the thermostat, ECT and did a coolant flush. At Idle the temp gauge is fine. However at speed the temp gauge climbs quickly. Is the radiator clogged? Is there a way to verify before replacing.
Well, for starters, with the engine cool, drain a bit of coolant into a clean container so the top of the radiator is visible. Look in with a flashlight.
Does it look like the inside of a beer can? Go drain a beer to have a good comparison.
Is the coolant a clear green?
Was the coolant you drained before the flush a clear green?
Have you gently cleaned the outside of the fins with water from the engine side (best to pull the shroud before hand, and BE GENTLE, the
fins are ever so easy to bend).
Did you burp the radiator after you did the coolant change? You have a 2003, so it's an automatic. the '01 automatics had two burp points,
one just in front of the firewall dead center, and one on the front of the engine (my stick shift doesn't have that one).
When you replaced the thermostat, you did replace the whole thing including the aluminum housing?
When you refilled it, what antifreeze did you use? Did you use distilled water?
It's overheating under load. If that's happening at speed, it's NOT the fan system as the motion of the truck through the air pushes
plenty of air through. It's unlikely to be the water pump. Water pumps fail by leaking, but they still pump water. Either something
is preventing water flow, or something is preventing air flow.
Chuck
