We've been keeping n eye on this issue for several years now. I'm not convinced it's a real issue, because:
1) Lots of engines have similar oil consumption issues
2) Data is clouded by high-mileage trucks with bad rings
3) Bad PCV can cause the same symptom
4) The issue was originally determined to be a Maxima problem (same engine, but different configuration for FWD).
5) The VQ35DE was in a LOT of RWD vehicles... they should all have the same issue, but don't.
I'd follow the path that's been blazed by several other VQ35 owners - install an oil catch can - AFTER you replace your PVC. Monitor consumption after replacing the PVC and see if that clears it up. If not, the oil catch can is a smart addition, and will also prevent lowering the octane of your fuel and should improve mileage somewhat.
You can search this site for "oil catch can" threads & articles, and here's a video (specific to the G35/350Z, but helpful):
https://www.youtube.com/watch?v=zApaVJnmi_U
