AlekAuto »
https://forums.nicoclub.com/alekauto-u316554.html
Sat Nov 08, 2025 12:36 pm
When I say "no brakes", I don't mean a spongey pedal. I don't mean you have to bottom out the pedal to get braking power. I mean it has NO brakes. 0. It's like the brake pedal is attached to thin air. Brake light is on. This leads me to believe possibly air got into the ABS module?
You can build up some, extremely minimal pressure with the engine off. Like, "I definitely wouldn't drive this" minimal pressure, and it loses that pressure if you keep it depressed until you're at the floor. And then once the engine is on, any semblance of resistance in the pedal instantly goes away. Master cylinder? Worked absolutely fine when it was parked.
Vehicle sat for a few months, I changed the pads and rotors in the front, and on the passenger side, I didn't crack the bleeder before compressing the caliper piston because I'm an impatient bastard who didn't wanna get up to grab the brake bleeding bottle.
I didn't perform a fluid flush after this, and I plan on doing so on Monday, but the situation in which not doing the flush when using the bleeder bottle on one single caliper and topping off the brake fluid could result in NO brake pedal whatsoever is strange and esoteric to me.
No leaks, fluid level never changes.
I should also note, I recently changed the valve covers out, as well. Maybe something I forgot to reconnect when doing that job? You have to take the intake manifold off. I can't imagine what could cause NO brake functionality, seeing as the only thing I could imagine forgetting to reconnect is the brake booster, and that'd result in a hard brake pedal. Everything I know can cause these issues causes a spongey pedal or extreme travel, NO brake pedal while having a full master cylinder reservoir is unheard of for me. Basically makes it impossible to diagnose when the symptom is "nothing happens for no apparent reason". Except I guess the behavior when the engine is off feels kind of like how a bad master cylinder feels?
Rear drums needing to be re-adjusted? Wheel cylinders leaking? Master cylinder's completely f***?
Basically my flowchart right now is:
Do the full fluid flush, starting from the proportioning valve and moving up to the front driver side
Redo the shoes/wheel cylinders if it's still a problem
Replace the master cylinder, and if I can see a leak from the back of the master cylinder, replace the brake booster as well.
After that, I'm out of ideas. I'd like to hear if anyone has any better ideas than me or ways I can actually properly troubleshoot it before I just start throwing the parts cannon at it, though. Could there bed something wrong with the pedal itself? That seems difficult to imagine, seeing as you can build some resistance when the engine is off.
Thank you for any of your ideas.
