fueler »
https://forums.nicoclub.com/fueler-u54519.html
Sat Jan 20, 2007 7:49 am
CHECK THE FUSES UNDER THE DASH, behind the coin tray. I believe there are separate fuses for each, example "left high beam" "left low beam" "right high beam" "right low beam" (edit - just saw you have a different year than i do but there should still be a fusebox under there somewhere) there is a schematic attached to the coin tray itself, the coin tray pops out for easy access.
